Exhaust 2006 RX400h
If the silencer is OK and the cat is ok, an exhaust specialist would be able to make a new piece to join them together at reasonable cost. Alternatively  if the pipe is not too bad, a general welder may be able to patch it up.
Mine is doing exactly the same in the same spot, I've ordered one of these off eBay, I'll either cut in half and then clamp the 2 halves over the offending area, after filling it with gum gum.
https://www.ebay.co.uk/itm/253781813427
From what I have measured the exhaust pipe appears to have an OD of 2.25" or approx 57mm. I'll find out when it arrives.
  • 1 month later...
