Went out yesterday heating working fine but today it would not warm up at all 😕.
Slight heat from side vents but footwell cold and no heat to rear passenger vents.the more I use this car the more I realise it's the worst car I've ever had.the foot wells still fill with water 💦💦💦
Oh dear, that's not good John.  Re foot wells I'm guessing that you have the sunroof option and maybe even roof rails?  Sadly both are known issues with water ingress.  Check, clean & clear drain holes & fitment areas ... but I think you probably know all that anyway.
As for heating, Malcolm is on it, maybe a pressure test if no obvious leak.  Radiator?  Sticky thermostat?  Does car temp guage vary?
Whatever it is I wish you luck, try & stick with it as these buses should in reality be reliable and relatively problem free given a sound service history.
