Skip to content
View in the app
A better way to browse. Learn more.
Lexus Owners Club
A full-screen app on your home screen with push notifications, badges and more.
To install this app on iOS and iPadOS
  1. Tap the Share icon in Safari
  2. Scroll the menu and tap Add to Home Screen.
  3. Tap Add in the top-right corner.
To install this app on Android
  1. Tap the 3-dot menu (⋮) in the top-right corner of the browser.
  2. Tap Add to Home screen or Install app.
  3. Confirm by tapping Install.
Rear wiper noise
Featured Replies
I have just been to halfords and the kind lady behind the desk let me try new one before buying to see if it's the wiper and unfortunately noise continued with a brand new wiper. Please can someone advise me what to do and where this noise may be coming from?
Sounds like the screen just needs a clean? Have you lifted the arm up and tried it just to confirm?
  • Author
Yes. It didn't make any difference.
Oh dear. WD40 down the shaft maybe?
  • Author
lady at halfords just did that. it made zero difference.
Sorry, I'm not being much help to you then! Hopefully someone else will come up with an answer for you.
  • Author
@ColinBarber
Please can you help me?
Back to basics:-
1) Have you cleaned the rear screen properly - then tried it?
2) Have you lifted the wiper away from the screen AND then tried the rear wiper ( with the wiper not touching the screen?)
Have you actually done these things?
I'll also step into the breach Mr BeFourYouTwo to give @ColinBarber a break, I expect he needs a holiday!
On this new thread topic, from which I must not tempt myself to digress, I suggest that you allow the WD40 time to do its work & let it lubricate the rear wiper arm mechanism.  On such an old car the moving parts are probably reacting to years of misuse, neglect or both, rather like some of your other publicised issues.
It should go without saying that you must NOT use lubricant on either the wiper rubber or the screen, but I'll mention it anyway!
Believe it or not my 400h was emitting an even worse 'grinding' noise emanating from the base of the wiper arm which is almost certainly from where your noise is coming. I gave mine regular doses (not excessive mind!) of WD40 over several days & the noise is no more.
If the noise continues to persist then the entire wiper assembly might need to be removed for a proper dose of grease, an action that I would NOT suggest you do yourself for risk of damaging the screen glass which is an integral element. Obviously.
If you still think you're stuck then I would earnestly suggest a comprehensive time & motion research of this Forum (and probably YouTube as well!) as the answer to most questions can be found by using a little time & diligence like most Members tend to do.
Good Luck bud.
  • Author
2 hours ago, Spacewagon52 said:
Back to basics:-
ABSOLUTELY!
  • Author
Good Luck bud.
surprise surprise now i just went outside with WD40 in my hand to spray it again but there was no noise..... happy days!
Long may it last.......gosh....these cars definitely have a mind of their own which don't make any sense at all.
I just wish all these little niggles didn't happen in the first place (despite the fact my car is almost 18 years old)
Well now, there's a thing.  Excellent news 👏
  • Author
Thank you!
  • Author
1 hour ago, Spacewagon52 said:
It is 18 years old - even a Lexus will get issues. It is not a new car.
I know that but want everything to be the best it possibly can.
Seriously - given the pages of posts about your car, are you sure you did the right thing buying one 18 years old???
Whilst not wishing to appear to criticise any Lexus driver for worrying about their cars making strange noises - I'm the very much the same I hasten to add - but I strongly suspect that Lexus drivers have become sooooooo used to a quiet and stress-free ride that any noise...no matter how small or seemingly insignificant - will set alarm bells ringing.  What's the betting such threads on a Lexus forum outnumber the strange noise threads on a Ford owners' forum? (as Ford drivers have to quickly get used to strange noises - nothing against Ford drivers...I've had 3 in my time)😆
  • Author
LOL well i can't afford a new lexus and didnt want to spend so much on a newer model so went with this.
Best to start small and work my way up but was adamant to go for a lexus because love the cars with a passion.
 But you’re clearly not confident hands on with cars going by most of your posts so buying an old car like you have basically is unlikely to end well? I see you’ve posted a new thread tonight about a rattle under the dash. They can be fun chasing down but whatever you do - even considering a Lexus garage is hari kiri. You need to do some legwork and find a Lexus independent in your area otherwise this cheap old car is going to morph into an expensive old car.
  • Author
I am really enjoying the car but there are a few niggles (to be expected with a car of this age)
A sensible first Lexus.
  • Author
Thanks for your approval David 👍
  • 6 months later...
  • Author
Unfortunately this has started happening again 😕 😞
On and off which makes me wonder what is the cause.
Problem is intermittent....🤷
Any advice or suggestions to make other than above?
Maybe needs WD40 every few months, maybe a lubricating spray of Oil would last longer.
  • Author
35 minutes ago, Spock66 said:
Maybe needs WD40 every few months, maybe a lubricating spray of oil would last longer.
Thanks, any suggestions exactly which one?
Note: Your post will require moderator approval before it will be visible.
Join The Independent Lexus Owners' Club
Our community has been built by enthusiasts, for enthusiasts, and proudly run by Lexus owners' for over 25 years. As an independentnon-official club, everything you’ll find here, advice, support, and opinions, comes directly from members with genuine Lexus ownership experience. By being a member you can gain access to active community forums, videos, news, events and more...
JOIN OUR COMMUNITY NOW!
LexusOwnersClub.co.uk (“Lexus Owners’ Club United Kingdom”) is an independent, third-party enthusiast forum created for owners and fans of Lexus vehicles. We are not affiliated with, endorsed by, or in any way officially connected to Lexus USA, Lexus Canada, Lexus UK, Toyota Motor Corporation, or any of their subsidiaries, affiliates, or authorised dealers.
All content, discussions, and materials posted on this website are generated by users of the forum and represent the opinions and experiences of individual contributors. Such content is not reviewed, approved, or endorsed by Lexus Owners Club, ACI LTD, Lexus UK, Lexus USA, Lexus Canada, Toyota Motor Corporation, or any related entity.
LexusOwnersClub.co.uk makes no warranties regarding the accuracy, reliability, or completeness of any user-submitted information.
Any reference to Lexus trademarks, logos, or brand names is used solely for identification and informational purposes. This site does not claim any ownership of Lexus intellectual property.
For official information about Lexus products, services, and corporate communications, please visit the official Lexus website relevant to your region.
Background Picker
Customize Layout
Account
Navigation
Search
Search
Configure browser push notifications
Chrome (Android)
  1. Tap the lock icon next to the address bar.
  2. Tap Permissions → Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  1. Click the padlock icon in the address bar.
  2. Select Site settings.
  3. Find Notifications and adjust your preference.
