Just had a problem on the family lexus...driving along temp warning went and steam out the front - rac think the radiator is gone and needing replacing...any idea how much will cost and how long a job? Also worth getting done at lexus uk rip off rates or going somewhere else (suggestions in the St Albans Herts area welcome!)
Thanks.....Stu
Hi Stu,
Get someone in to take a look and see if the rad can be repaired. I had to do mine a while back and so far - touch wood - not been a problem.
A new rad can cost anywhere from £400 upwards, a repair only cost £200, that also with a new core. If you have a look through the Yellow Page - Yell.com under radiator repairs, you should be a ble to locate someone near you.
Hope this help you.
BR
Paul
Also Welcome to the Club.
yep pauls is the best idea,, at least a repairer will say if it can be mended... a garage will just want to replace it no matter if it can be repaired or not..
welcombe to the club
craig
See if it can be fixed, otherwise...
I recently had to get a new radiator fitted, and Lexus price was way over £500.
The garage I used found a brand new pattern part for £200+VAT. You just need to speak to some motor spares places and you should be ok if you want to buy a pattern part.
Just in case, here's a place in the US that sells rads for Lexus. Your one would cost $256 (£146) + postage + duty.
http://www.carpartswholesale.com/
Sounds like it would be a pattern part.
Here is another place selling Lexus rads cheaply.
The link is for an LS400, but they would do GS300s too.
http://www.webradiator.com/autoparts/LEXUS/ls400.html
When I had the mk 1 I had to replace the rad which the dealer wanted over £400 for (part only). I managed to find a place in leicester which did a pattern one for £145. I cant remember what their details are but i think they were called "Leicester radiators", try directory enquiries.
Sign in to follow this
