Tired The Kit From Gobal Yesterday
norkep
A bit of hard work Bret, it's a metal polishing kit I got from Pete. Just followed his instructions and an hour later, a nice shiney rim on the alloy. Had all four done by mid morning.
My alloys are not lacquered, so polishing was easier but if you tried the same on a painted alloy, expect you'd burn the lacquer off and dis-colour the paint underneath.
No - A circular stiff brush attached to the end of a drill and some cutting compond, then a softer buffer mop again with some soft compond and then a soft cloth mop with a polish clay of some sort. Everthing was done with the use of the drill. Just needed to be carefull of not over doing the polishing or I'd cause a flat spot and not even shiney surface.
Thanks for the comments though, going to give another go tomorrow weather permitting, can only get better with practice I hope.
