Flaming Oil Leak
bowker
Oil Leak
I woke to find a puddle of oil under my car this morning :tsktsk:
It appears to be from the front part of the engine just behind the belts near to where the water pipe is
Sorry about the crap pics
Good job I have the lower engine cover off or wouldnt have seen it
Anyone any idea what it could be
Oil Leak
is it oil or fluid form the waterpump pipe
:D that is no oil leak matey, it is the water bypass valve which is leaking.
it is a very cheap repair and does not take long to sort, if your car is under warranty then it is covered if not it is still not a big problem..
the reason why it looks clean is that the coolant is that colour..
hope it helps but me thinks i am 99% certain :D
:whistling: defo not oil that as he states it wasn't that oily when wiped off the drive, but it does look sorta red when you look at the picky..
put money on it that it is the by-pass valve :winky:
I will get some more pics when I get my camera back
I bougth extended warranty when I bought it so will look at the paperwork thats at work tomorrow
Is it just that bit of 90 degree angle pipe bolted onto the engine??
There was none yesterday then it came back again today
I have recenty bent my rad a little and its pushed it up at the bottom but not put a leak in it
Could this of somehow caused the leak?
