Is 220d Sport Sat Nav
Hi All,
Just wondering if anyone might know a way to override the sat nav so that a passenger could load a destination whilst the car is on the move :question:
In the demonstrator the system disabled itself whilst the car was in motion.
I take delivery of my IS 220d Sport tomorrow and it would be good to have the override option.
Pat
Lexus Pat.
There is a tempory override.
Push the Menu button.
Select the Volume icon.
On the volume screen, touch screen Top LHS, then Botton LHS, then Top LHS, then Botton LHS.
This will give you a screen of about 8 options.
Press and hold the Override option (3 down LHS, from memory). Hold for about 5 seconds and it will change colour to a blue background).
Go back. Go to Destination screen and you should be able to change destinations, etc.
Only works for Sat-Nav and will go back to normal when you stop/re-start the car.
I have used it a number of times and has worked everytime.
Have to make sure that car is running and when you push on the "override" line, you hold your finger on it (screen) for about 5 or so seconds and when you take you finger off, the background box on "override" has changed colours.
Then return to Navigation.
