Vibrating Rear View Mirror On Is220d
Well after recently complaining that my rear view mirror vibrated, I seem to have cured it! Playing around with it I noticed it hinges in two places, and by moving the top hinge around a bit I seem to have solved the vibration problem completely!
Not quite sure how I managed it, but thought I'd pass it on.
The proof will be to try at 70mph in 6th...it's worst then....
...or if you have the MM option, whack the stereo on 50+ as the centre speaker can sure move that mirror!
WARNING: Doing this may serious damage your eardrums - but it does sound good (whilst you can still hear) :hehe:
regards,
David
Does 65 in 5th count? It used to be a problem at all road speeds for me, and this has seriously improved things. Shame I wasn't really paying attention to how I moved it - just random wiggling (which I'm sure should normally only be carried out in the back seat..).
I ahve the vibrating mirror too. i'll try to adjust it tonight. thanks for the tip!
I have noticed this too will try random wiggling 2moro! :winky:
