Slightly Leaky Strut?!?!
Sven
no, you cannot fix this yourself. They are referring to the damper of your suspension system. It is common for old IS's who have been thru years of spirited driving to leak.
I think your only alternative is to replace it. Either 2nd hand stock, brand new stock, or change ur car's suspension system into an aftermarket one.
i bought a pair of new struts from
www.buypartsby.co.uk
Cost me £110 delivered to my door.
These are the same KYB dampers that the lexus dealer will supply to you.
Make sure you replace them as a pair though and not just the damaged one
