Help With My Double Din
Anyone bought Fargo's Module?
I have it bought works perfect for the sat nav
but the wiring for the speakers? I cant figure it out...
Do I have to cut the amp or is there a way to keep the stock amp and stock speaker?
Thanks so much for your help
atm minute the best way is to re wire with aftermarket speakers.
I have a lead coming on monday though which, if it works, will mean you can use all the standard speakers.
I think this may only be a temporary fix though as i'm not sure how much power the OEM speakers can take. I don't play music that loud anyway so be ok for a fair while.
so i should start cutting wires from the stock amp?
No, should be no need to cut into the stock loom.
This kit i'm waiting on plugs into the amp and has an ISO connector on the end for an aftermarket stereo.
If you are going to replace the stock speakers then leave the wiring in just run some new speaker cable to the front and attach your own ISO connector.
Problem I have is time. Either spend around 3 - 4 hours rewiring or about 10 mins installing this new lead...
http://www.lexusownersclub.co.uk/forum/ind...showtopic=37720
So you have ordered it?
The problem is mine IS is with sat nav
do you know if that connector can connect to Frago's module?
Ordered it and itr arrived yesterday, just nobody bothered telling me till this evening, so will have to take a look on Tuesday afternoon now.
Keep checking that thread because as Stav said Fargo has contacted Pete about making one that incorporates his module for the sat nav.
