At-oil Temperature
Aristo161
Hi, would anyone tell what is the normal temperature range of ATF :yawn: ? I found that when the ATF temperature goes up to 80 - 100 degree C, then the throttle response becomes worse and worse. And the ATF temperature come down very slowly even at normal cruising.
Does the stock radiator come with ATF cooler?
Happy new year !!! :D
Ken
