Which Clutch
ALI_1
If your car is pretty standard performance wise then just get an OEM clutch. Or blue print? If you're after a performance one then a Helix organic clutch is excellent. It can handle more power and abuse and also still has an OEM feel to it. If you want one that can handle LOADS of abuse then a Helix Cerametallic clutch is also excellent. Its a 'paddle' clutch so you can't slip it but its not too heavy and with a bit of use is very easy to drive with. It can be a bit of a pain in the arse starting on hills though and crawling through motorway traffic etc..
I've had all the above and are all excellent. It just depends on what you want / need :winky:
Thanx for the info my car is standard no mods etc so il think il go with a blu print one what kind of price should I be looking at I had no idea that there were so many clutches out there honestly (learn somthing everyday!)
  • 4 weeks later...
I do the blueprint clutch for somewhat less than £200 :winky:
PM me for details
Dave
