Buying A Used Is200
Geoff D
I am considering a 3, 4 or 5 year old IS200 as a long term buy - Possibly as long as ten years.
Is there anything I need to look out for?
Do high mileage IS200s suffer any particular mechanical problems?
Looking forward to any help I can get.
Thanks in advance.
Geoff D.
Guest inicol63
Thanks in advance.
Geoff D.
Hi higher mileage cars are normaly ok if they are well serviced and looked after.
Some is200 have problems with there stereo.
Check through the forum on the most common problems.
It is worth having a A/A RAC inspection if you are looking to keep long term.
There are a few cars on here for sale which are well looked after cars, could be a good starting place for you.
Good luck and welcome to the forum
yep follow the guide above,also cars sold on here are probably the best examples in the country.Although we have 2 AU Cars from Lexus and have never had to use the warranties on either.They still run perfectly.after 5 and 2 years respectively.Most people on here are really anal when it comes to their vehicles,so they turn out to be really good owners.good luck
