well carefully taken the door card off and everything seems intact , checked the amp that seems ok 2 now im really puzzled would check the head unit if i knew how to get it out any help would be happily recieved
nise motor buy the way how did you get those wheels so polished by the way1 back to the speakers though , everything seems connected ,but there is no sound comin from the passenger side door tweeters or mids i'm thinkin there's gotta be a brake in the wire some where . what do you think?
thanks for the reply
pete
the head unit comes out as one unit and is held in by a few screws but to be honest its been a while since i took mine out so i will let one of the other mk1 owners give you a more detailed explanation .as you say it sounds like a break in the wire could well be were it gos into the door .
I take it all the other speaker are working fine.. have you checked your balance/fader, If you had taken the door card off have you checked with another speaker. Other solution is to fit new wires. It could also be a loose connection or a wire which has got cut or come off.....
Just some suggestions...
