Is300 Hid Headlamps
hey guys,
U propbably guessed by now, ive the got the “Ebay bug”!
Found some Complete headlight units for a US IS300, costing $200-300 (auction still on).
Was thinking to bid for them and replace my current headlight units with these HID ones.
BUT would they fit, would i be able to easily swap my IS200 ones for the HID ones? These also have the clear side indicators…. which look v good :D :D
You would also need to have the ballast/ignitor box to make the HID's work, so check it comes with this. Its not just a case of wiring the existing headlamp feed to a HID lamp. Also, legally, you should have an auto light levelling system fitted with HID's but it is up to you wether you fit one....... :blink:
READ MORE ABOUT HID HERE
It says that the ballasts/ecu's are included with this auction, so it might be worth a look......
I am unsure if they can be adjusted to dip to the left for UK cars though???
I wonder if part number gurus Chris or Gordy can find out if the LHD and RHD HID units have the same part number????? :shifty::shifty: :D
