15bhp would be a pretty meaningless upgrade in power in terms of everyday driving. i've never heard of anyone chipping a GS300 in the UK or anywhere else.
if you want genuine POWER upgrade, add a turbo or supercharger.
however, personally, sort the stock suspension out before you go adding more power. the standard GS drives like a boat as it's set up for cruising.
I'd say look at sorting the handling & brakes.
coilovers/TRD anti roill bars/TRD bushes/TOMs-TRD-C-One chassis braces
You could then look at induction kits,exhausts,de-cats,manifolds and a CAMCON
If you have the budget then there are supercharger kits and turbo kits available (low boost)
the latter will give more BHP but comes at a greater cost
Where in the uk chips gs300's and what power increase does it give? anyone have any ideas? thank you.
To answer your question, the way we do it is to use a sub cumputer used in "piggy bag" mode which enables the fuel and ignition to be recalibrated.
You will not see a huge increase but it is worth doing.
Hope this helps :)
Or add a nitrus kit :whistling:
I got a proportional injection kit winging its way from the jolly old US of A
So shouldnt be long before I scare myself stupid again
I want nitrous on mine...how easy is it to fit? oooh, i want some!!!!
