Is200 Hifi
my cd player has packed up, it initially would not play past track 5 of any cd (even new ones), attempted 2 clean lense but now will not work at all (error 3 comes up on panel).
1)Anyone any idea how to clear error
2) now several people have upgraded systems, does anyone have the origianal head unit they would like 2 sell?
year2000 is200 sport
thanks
If you are thinking of fitting a 2nd hand unit its worth checking out the plug config, I've seen 2 different types not sure whether its a year or import thing. But will save alot of hassle. Good luck
I've got the same prob. ERR3 showing. If I buy a freakin Lexus, the last thing I expect to be doing is bashing the centre console/pulling fuses to get me freakin CDs out. I'm just under warranty so I will be going back to PLYMOUTH LEXUS to get this thing SORTED or all poo will hit the fan. Poxy bl%dy thing...
The plug configs are 18 PIN connectors on the older ones (cd slot at bottom) and 20 pin connectors on the newer one (cd at top)
I also hae my old HU for sale its the Newer 20 pin one
Si
Si,
The 2 head units i looked at were both bottom cd units, 1 out of a T reg the other a W, only the main plug looked different like you say has more pins. Had a nightmare with a breakers who sold me a knacked unit, they told me they tested. When i sent it back they said i'd swapped it for mine, had to drive 150 miles round trip :angry: just to sort it out ,anyway to cut a long story a bit shorter thats when they produced this T reg unit that had more pins, and tried to flog me that. Wanted to cut the loom to fit it. so with that i took my money and run before the side cutters came out
