Lsd ?
Fast_Jap
Cusco and TRD ones are available from Prolex-UK and TDI for £500 at least I think.
For the Sport model one, I have no idea but you may be able to find a used one in a scrapyard
Oh, same as your website then :lol:
Is it a case of unbolting the current SE diff and bolting in the s/h lsd to same bolt holes? ie Is fitting your s/h lsd going to be laden with complications?
How many miles have been clocked up on it?
I have an '04 SE and don't got LSD :msn-cry:
Insurance co I used last year wouldn't let me add the LSD :tsktsk:
The co I'm in process of renewing with will insure me with LSD without additional cost!! :D
So getting back to my query then, can the diff on the SE be simply replaced by Sport LSD???
Hm... usefull to know, i always thought it would be a major job changing from the se diff to a lsd.
Will have to add to the cars wish list!
I know this may sound daft but is there a huge difference, never really under stood how they work, completely boggles my mind!
  • 4 weeks later...
Hello mates, been a while...
I have obtain a complete Altezza rear axle with lsd, framework(btw hows that said correctly), brakes etc.
So now the question is; What is the difference with Altezza and IS200 output shafts ? Lenght ?
Will the Altezza shafts fit straight to IS200 wheel hub ?
Edit: Replying to my own question IS200 has 4-bolt and Altezza 6-bolt shafts BUT are they same lenght ?
I do not know if this can help you:
You can change just the center lsd instead of the whole differential.
I also wanted a oem lsd please warn me if you find another :winky:
Ah sorry my mistake then :) The guy told me its a viscous, i thought wtf, what car is it from ? And he said Altezza but from Japan, so i was supposed to ask you guys is it possible... at least the ratio is 4.083
Well should i change the hole crap with tezza shafts or only the differential...
Thanks very much btw ! ;)
