Altezza Rs200 Auto Gear Box Problems
sezkev
Hi all
need some help with my altezza? the autobox just gone wrong would anyone have wiring diagram for gear box side
of car also has anyone had any problems with there auto box? symptoms are not going in to 2nd when i set off in "D" also torque convertor locks up sometimes and engine will cut out
Thanks Kev
Hi all
Thanks Kev
Well all the tiptronics won't allow you to select 2nd gear until they are up to the correct temperature to prevent damage... maybe the temperature sensor to the ECU is faulty?
as for the stalling... no idea :(
good luck hope you get it sorted ;)
  • 2 months later...
Hi first off happy new year to all, just a qwick update on my gear box problem it was the gear box at fault ,the cars now back up and runing :) so i am well happy again apart from the big hole (£1200) in my pocket now but hay thats life.
I worked out that the performance of the car is so much better than it was when i bought it so it must have had a problem to start with. Thanks to all members for help.
Thanks Kev
