Removing Aftermarket Coilovers?
IRLRs200
So need to take my coilovers off and throw the standard shocks back on. Is there much to this? Is it as simple as putting the car up on ramps take off the wheel, undo the 3 nuts holding the coilover on at top, then the coilover should just drop down? How are they secured on at the bottom? I have access to ramp so that should make things easier
Taking the coilovers off will proably me easy, it putting the standard stuff back on that will be hard, removing them is basically take off the 3 nuts at the top the undo the big one at the bottom of the strut, you will need a ball joint splitter to do the fronts though, oh and some spring compressors of the standard springs!!!
