Obd2 Cables! Where?
golfvr6, Here is the link to the one i just bought! certainly hope its the right one now its ordered!!!
http://cgi.ebay.co.uk/ELM323-USB-CAR-SCANT...1QQcmdZViewItem
exactly the same as i have so you will be fine - if it doesnt work when you install it u will need to install usb/serial port software - i had to do this on XP and vista, i got it from microsoft
  • 4 weeks later...
  • 3 months later...
could this be used with the software in the same way?
Item number: 130247636481
-thanks
You'll need the reader aswell matey to go with that cable?
I use the new free full registered version of ProScan V5.4 software for my elm327, which i downloaded from the scantool website and works very well. It even does the fuel economy :)
where on Microsoft pal? i cant find the software, have you got the name or link please?..... iv just got the elm 327 cable and cant get it to work as the device does not get recognised! please help someone
-thanks
have you got a link or the serial for pro scan v5.4 pal? i cant find it anywhere
-thanks
I'll have a look at where i got it matey and pm it to you, You have to search for pro scan 5.1 as the 5.3 and 5.4 are new updates and 5.1 is the main system from what i've found out :)
