Electronic Guru's
Hi guys.
Need a little help from those of you more accustomed to electronic (car wiring).
A mate of mine is replacing his standard OEM Pug 306 stereo for an afermarket Kenwood number.
Between us, we've worked out what Pin numbers and ISO connectors correspond to the designated function, but the problem arises with regards to the wiring.
Basically, the new kenwood system list:
Yellow = Battery
Blue/White = Power Control
Red = Ign (ACC)
Black = Earth
but the standard wiring is coloured:
Red
White
Orange
Yellow/Green stripe
so which correlates to which??
cheers in advance fellas
rob
The best thing mate is to use the old multimeter, as the colours vary between each car maker i mean for example a vauxhall ground is BROWN
but on our faitfull lexus its something else
sorry i cant be any more help some one elsemay be along shortly with a bright idea (I dont mean a spark)
Positive should be showing permanant 12v+current,
the acc+ will only show 12+ current when the ignition is turned to the acc position
The earth will show no current
And not sure but think the remote wire will show a low current with the ignition turned on but dont quote me on that :D
Positive should be showing permanant 12v+voltage,
the acc+ will only show 12+ voltage, when the ignition is turned to the acc position
The earth will show no voltage,
And not sure but think the remote wire will show a low voltage, with the ignition turned on but dont quote me on that :D
There all between the wire and earth (any bare metal bit of the car)
