hi,
it would have been easier if it were the other side, the near side (passenger) has less space to get your hand in. i end up with a few cuts to my hand. :(
you need to turn the connector either clockwise or counter clockwise, sorry i cant remember which exactly. but it will only move one way. once its moved, you should be able to pull away and change the bulb, then insert it back in and twist lock it into place!
Further to this topic of side lights; How can i make them brighter? The standard 5w bulbs are very dim and don't look too good when on.
Just replace my Xenons with the 6000K Replacement D2R Bulb and i personally prefer them to the ones that where in there.
You could try the hipower LED version bulbs or the pia versions as some give out a more cleaner light and dont look yellow so will match your headlamps a bit better? :)
Any ideas where I could get some from, as I agree the yellow aren't so nice, brighter ones would be a lot nicer.
