Airconditier Heating Does Not Work At All
The heater matrix is very big job to change usually and wouldn't look towards that yet.
Maybe it could be the solenoid on the heater control valve but don't know your car so couldn't tell you where it is I'm afraid.
Also, there is a 'flap' (blend door or damper) that moves across between ducts for hot or cold. I don't know where yours is but you can usually manually moves these over from under the dash. It will be around the heater box / hvac somewhere. If it is this, it could be the flap sticky or not getting control power.
Have you done anything with your coolant? It could be an air bubble if you've drained or let it get very low.
  • 1 year later...
