Ebay Decat And Short Shifter
Crunch
http://cgi.ebay.co.uk/LEXUS-IS200-2-0L-STA...id=p3286.c0.m14
http://cgi.ebay.co.uk/LEXUS-IS-200-IS200-1...1742.m153.l1262
Anyone used any of the above, will i have any ecu probs with the decat? It says it has a hole for the 02 sensor.
Also anyone used the short shifter, i fitted a 15 quid eBay short shifter to my last car and it was awesome, really reduced throw.
Cheers, Dom
Theres just been a huge thread on here about the IS200 manifold the same seller was flogging, and unfortuantly they didnt fit.
I was under the impression the centre cat sections vary with years so i cant see how he can offer a "one size fits all" centre section, but people are yet to try it.
As for the short shifter, i really dont see why it wouldnt fit perfectly (i have a B&m one) but its how smooth it is when fitted.
Cheers Stav.
His returns policy seems fair enough, so if it doesn't fit, he can have it back!
I can reassure you on their return policy; I was involved in the manifold issue and got fully refunded to my complete satisfaction, so I'd say shop withouth worries.
  • 1 month later...
you can use the original 02 sensor.make a spacer long enough so that when you screw it back in it is flush with the inside of the exhaust.i have done this with mine and runs perfect even with the manifold cats removed. another thought on this is maybe put sleave of somekind over the sensor so that it cant get the full flow of the gasses.
Thats another way, you can use "spark plug spacers" i think they're called.
I used an O2 sensor cause i've replaced it with a wideband sensor.
