Wheel Corrosion On A Rx400h ?
cheers folks . Now did you keep the wheels clean and free of road salt or did you just let them rot ? I wash my rims weekly through the winter so if it makes no odds then i won't freeze my nads off cleaning them as often .
jon.
  • 5 weeks later...
jon.
Jon keep your nads. My 54 reg had all the wheels corrode, four of them dirty and the spare shining and unused never out of the boot also corroded.
  • 4 weeks later...
Hi Jon
Bought my RX400 2nd hand privately at 2 years old with 34000 miles on in feb 08, just been in for it's 40000 mile service. I just happened to mention the wheels looked a bit rough (stone & curb damage), when I went back to pick the car up 4 new wheels had been ordered under warranty, fitted 2 days later. Result.
Hi Jon
Sweet .
As long as you catch this type of fault within the original 3 year warranty you will always get an easy remedy from Lexus. If you're lucky you will get refurb'd wheels rather than OE rims - which will be more than likely to corrode outside of warranty.
Ours had its original rims refurb'd prior to purchase and the seem to be doing just fine (ours is now approaching seven years old).
