Check Engine Light
JAMY
Thanks stevie and mark...Could the sensor not be faulty? maybe abit of cleaning will sought it out? what do u guys think?
The online workshop manual doesn't suggest cleaning it, so my guess is that wouldn't help. This is only a guess though, I don't know for sure. The main things suggested by the manual are a faulty sensor or a bad electrical connection.
Hi steviewevie,
Can you please give me the exact part number for the sensor. Cant seem to find it
Looking at this diagram I'm not 100% sure. It gives two different part numbers for the two O2 sensors on bank 1, but just one part number (89465-53150) for bank 2. I don't know if this is because both bank 2 sensors use the same part ?
I really don't know for sure and I'd strongly recommend you check with a Lexus/Toyota dealer or someone who can tell you for sure about this, if you're going to go ahead and order a part.
On second thoughts, since in that diagram it says "exhaust pipe" next to the sensor, then it lists part 89465-53120 and 89465-53190. I don't know why there are two parts, only the second one seems to have a price listed there.
But again, I don't really know for sure, so I recommend checking with someone who does.
They are probably all the same with different connectors on the ends of the leads. I had that with the Tezza when I replaced them.
The fault is in the heater not the actual sensor, all the heater does is get it up to operating temp faster. Buy a generic one, cut the connector off the old one and solder it onto the lead off the new one. Save a load, they are about half the price of the Toyota ones.
  • 1 month later...
u shld know evrythng u do to is200 oil change affects the system.pulling out cables etc.anythng tht affects engine perfomance turns that light on.
well the other day i thot let me check my air filter and realised its 1 of those japaneese filters.it was filled with dirt n all torn apart so i put it back n said id buy a new 1 the following day.i did start the car without the filter on n my light came on.so it meant too much air in the engine.so nw i had e light cum on n obviously i knew wat e prob was.replaced it reset my fuses n walla it hasnt cum bk on.
so u might need to check your air filter if its filled up with dirt.
seriously, full words and punctuation please.
