I am a new member having just joined the forum.
The instrument panel will not light in the cold weather untill the engine is warm on my LS400 has anyone had this problem
and how can i remedy this please.
Welcome to the LOC,
Please feel free to introduce yourself and tell us about your car in the new members section.
We are always happy to try and help other members with problems but it is always worth doing a search of the forum 1st as the subject of dashlights has been covered many times as it is a very common problem.
As Royt says Chris Vince is the man for this job but should you wish to DIY below is the link with all the info.
http://www.lexusownersclub.co.uk/forum/lof...php/t26776.html
  • 2 months later...
If its the LCD panel for temp and clock, this is a common failing on early models
Check the forums, sometimes the panels are on eBay, not cheap and fiddly to do.
Again check out Chris Vince
