Anyone Had Problems Fitting Induction Kit?
will THIS pipe be ok
how do you fix the pipes/ induction kit to the car, what would you use?
-Thanks
Yeh that pipe should be ok? which kit you making? short or the long one? :unsure:
im not sure yet but i think the long one just need to know what to use to fix the pipes down so they dont move about
You dont need a T piece for the oil breather just buy a button filter- the button filter i brought was £3.29 and the bracket to hold it in place you can use a hose clamp and metal tie which would cost less than a £1 :) so a bargain compared :) And the one i made was a lot less hassle fitting any covers due to its routing and the 63mm 90 degree pipe actually fits the throttle body :)
I cant find this button filter, can anyone direct me to where i would find one or have anymore info on it?
or i might add the pipe to the induction, could someone tell me what size that pipe is (diameter of the hole please) - im thinking if i can find the right sized pipe and use THIS in right size
-Thanks
thanks mate your a star, wile i got you here how would i fit the pipework down like would i need to use some sort of brackets to hold it down to the car so it dose not rattle about?
i'd use these with a hose clamp, bend them to shape and bolt using one or two of the original holes on top of the engine or radiator CLICK ME!!! :yawn:
Most universal filters come with adaptor rings for 60mm 63.5mm and 70mm iirc like this one CLICK ME! :)
are these filters as good as any of the branded filters like K7N or apexi? I was looking for a branded make but if it dosent make much difference i will just buy that one.
-Thanks
Was just looking at the prolex induction kits you guys have fitted, :whistling:
And if you brought one of these CLICKY And one of these CLICKY And 2 of these CLICKY From B&Q which are £10.99 each for a 60mm ID AND 750MM Lengh, all you'll need then is a slip on filter and 5 hose clamps? and you basicly have the same induction kit for around £50 plus the cost of the filter which you can buy quite cheap depending on the one you buy? :) saves a few £'s for little work and should run the same route as the prolex one? :)
funny you should come out with that, as i think i was the 1st one to make the kit and dave got all the size,s of my kit and just turned it around, where as my kit i made went over the engine to drivers side and down, :winky: and you are right the cost was only about £30 to £40 and i used all good items for my kit "ie" intercooler tube, and samco hose's, i did not go to BQ lol
