Stereo Problem
hi guys, slowly gettin the funds to mod the car, got a BIG problem.. went to put aftermarket cd player in, got the fasia etc went to plug head unit in and i need a special lead, does anyone know what audio lead i would need, as far as i'm aware the car hasnt got a built in amplifier so dont need to bypass that. I've got a long drive this weekend and really could do with some music to listen to!!!
is200jim
Your profile says you've got an SE, if so then you should have the separate OEM amp, which is hidden behind the glovebox. If you open the glovebox and then pinch the sides in, the whole thing will come forward and you will be able to see if you have the amp against the passenger side panel of the car.
