I had a leaky boot, even after I did the re-seal the boot rubber thing. Turned out the water was coming in behind the r/h rear light cluster. I took off the cluster- 2 bolts inside the boot, on the side of the car, and then popped out the 2 plastic holders that the light cluster metal pins clip into.
Refiting them with silicone sealant seems to have done the trick
Ian
Ian
Like it!
