Can I Change From 16inch To 18inch Alloys?
Can i change from 16inch alloys to 18 inch alloys, without damaging the car?
They're a Lexus option, so no problem, but if you want non-OEM make sure you get the right off-set to match width with the hubs. Do a search, there's loads of posts on the subject, or check this site http://www.clublexus.com/forums/is-second-...your-setup.html
  • 2 months later...
