Need Help In Trouble!
lexus2000
I don't pay too much attention to the Rev counter, but it sounds bit high. 3000rpm at 60mph. did you have anything like PWR down?
Will check the rev counter for you tonight on the way to home.
Felix
I'm guessing that if you're cruising at 60 and then flick the box from D to 3 it doesn't drop a gear?
I've never actually heard of any problems with the IS200 auto box before so can't help further sadly.
You're in D in both those pics though, get it up to 60 or 70 and then slide the lever over to "3" and see if it drops a gear.
However 2.5k revs does sound high for 60mph in 4th gear so does sound like it's probably in third.
ALso your engine light is on so might be in limp home mode which is causing a problem?
Good spot, it could be another problem that's causing the gearbox to behave funny. Have you had the codes read to see what the fault is?
Hi guys.......
the pictures are mine last night. not Lexus2000. I did have engine light on for past a few days, and it has been sorted now.
I don't think I have any issue with my Auto box at all. Auto box was service by the B'ham Lex just after new year.
the pictures I put up there are only to show lexus2000 my speed/rev .....
I will take a few different ones tonight show you guys later...
Ta...
can everyone with an auto box post the following please:
with cruise control set to 50mph flat motorway what's your rev:
with cruise control set to 60mph flat motoway what's your rev:
with cruise control set to 70mph flat motoway what's your rev:
with 70mph flip to 3rd from D, what's your rev:
many thanks I will report mine 1st thing tomorrow morning or tonight when I got home.
1st report:
50mph / rev: 2000 rpm On D
60mph / rev: 2500 rpm On D
60mph / rev: 3500 rpm On 3rd
70mph / rev: 2900 rpm On D
80mph / rev: 3100 rpm On D
of cos I didn't go any faster than that....
let me know if anyone wants the Pics, couldn't be asked tonight....
Felix
1st report:
50mph / rev: 2000 rmp On D
60mph / rev: 2500 rmp On D
60mph / rev: 3500 rmp On 3rd
70mph / rev: 2900 rmp On D
80mph / rev: 3100 rmp On D
Felix
My GS300 is at around 1600rpm at 60, just under 1900rpm at 70................ :whistling: Sorry, this doesn't help in finding statistics but I thought I'd add to the fun.
Mine were exactly the same, so I think it's fine. Never noticed the revs were so high but I guess it explains the poor fuel economy.
who cares about the fuel economy?
actullly I do.....
anyway.... so lexus2000! you check with yours, if they are different, you have an issue. Make sure your test it on a flat motor way!
get it checked out.
Felix
  • 4 weeks later...
