Updating The Is200 Sport Sat Nav
How can you update the sat nav in the IS200 Sport? Mine's coming up with some error message and update dvd etc, I will get the exact message and put it on the thread later today
Try taking the disc out and cleaning it - I had the same problem a few years ago, a good clean sorted it.
If you want to update, visit www.lexus-mapupdates.eu :)
Hi there,be careful what you clean it with though,as for disc/map updates,got the 2009/10(set of 3 discs) cost me £139.00
Might be a stupid Q, but where is the disc? :blush:
It's in the boot, lift up carpet and plastic tray, it's on the right of the spare wheel. You'll need to remove the cover from the front to remove the disc.
There's a metal box to the right, do I just take the bolts off and open that? What do I clean it with or just wipe it with a clean soft cloth?
That metal box is the nav unit, you don't need to unbolt the whole unit, just the panel covering the front of it.
I cleaned mine with a soft lens cloth, as long as you use something soft so as not to scratch it it should be ok. If it's very dirty then you might need to use some kind of lens/cd cleaner.
I've sorted it now, I just unplugged the two clips and plugged them back and all is ok. Thanks for all your help :)
Great stuff, glad it was a simple fix :)
Spoke too soon, it's done it again! I think I may need to update it
