Hi all,
As of late I seem to be getting this "banging sound" when coming off/on power suddenly, the harder I press the accelerator the harder/louder the banging sound is.
Sometimes it also happens when going from Neutral into Drive and very rarely when from Neutral to Reverse when standing still.
It's coming from the rear sounds like something is wrong with my prop/diff?
Has anyone else had this problem? The car is a 1996 LS400 by the way.
I intent on checking it out next week as I have a few days off and would just like to have a rough idea on what to look out for!
Hi all,
Just a thought, but is the transmission fluid at the correct level?
Wouldn't have thought it was the transmission,I believe there are rubber couplings on the propshaft which may be worn but check all the rear suspension rubbers and mounts,another possibility is worn engine and/or transmission mounts again these do fail so worth a look.
