Alloy Wheel Fitment
lex 85
they will physically fit yes, but the inside edge will be 10mm closer to the suspension, and the outside edge will stick out 40mm further than the stock rims did.
you can use THIS calculator to work out any other combinations you try. :) stock wheel offset is 50mm by the way.
Thankyou for the reply, so will they catch as theyre quite a bit wider
you will need to run a 215 tyre or you will get lots of rubbing and if you've lowered it a lot your arches will sit on the tyres...
i know i run a et35 but mine are only 8 inches wide.
