Afternoon all
we have a 1994 LS400 & we want our central locking to work off the remote, does any one know what battery it takes & if there is a reset procedure?
i know its only a small issue, but its driving us mad.
sean
Hi. It drives everyone mad so you aren't alone.
What type of remote do you have? This is not as strange a question as it may sound. For example, MKIII's had a system fitted by the dealer and some have replaced this with a new system. Consequently, you can't necessarily assume the system on your car is standard.
Has the remote ever worked? Did you get any instructions when you bought the car (written or verbal)? Is there anything on the car to indicate the make/model of system such as a window sticker?
You could try describing the remote or better still take pictures of it and upload them - instructions are available by searching - or you could upload them to photobucket and just provide a link for us.
Once the type of system is identified, getting sorted should be ok.
Everything you need to know is here for the 1990 to Oct 1994 model
http://www.clublexus.com/forums/ls400/336540-diy-battery-replacement-in-lexus-key.html
Don't forget to check the switch under the driver's dash to make sure the remote is switched on!
