Small Discs Altezza Help!
altezzap
Bad luck for buying a base model. You need 275mm rotors. The genuine part number is 43512-22220 according to ToyoDIY.com You could try your local Toyota/Lexus dealer.
I know they use the same pads as the Lexus ES300, which also have 275mm rotors so that would be a good place to start looking.
You could always just put some twin pot calipers off a IS/RS200 on with the 296mm rotors. It's a simple bolt on upgrade.
I know they use the same pads as the Lexus ES300 & which also have 275mm rotors so that would be a good place to start looking.
Thanks mate,i know it's not the best model but it was a bargain!!!
Top advice and thanks for not ripping me apart for bring a newbie with a base model.... :lol:
