Sat Nav System
Here you go bud...... http://www.lexus-mapupdates.eu/
Just enter the number off your existing disc and it will tell you which disc you need to order but I'm not sure if the IS200 is still being supported.. I might get a set this Summer as I'll be doing a tour of Europe later on in the year
I have given up with mine (and since the boot mounted player has gone wrong anyway). The system is nearly 15 years old, and IMO outdated and difficult to use. I have disconnected the player and bought a garmin instead.... up to date, easy to use, postcodes, I have added POI etc etc.....I just miss the nice lady's voice telling me off when I apparently go across a field because the disc was out of date!
Hi, The driver is in the boot to the right of the spare wheel well.... From memory you have to unscrew a securing plate to be able to remove the disc but it has been a while since I've been in there... It should be reasonably self explanatory when you see it..
Hi,do it with the ignition on,updated my disc(s) in 2010 and it costs me £139,not cheap when you could buy a tom tom for that money.I however like things working as they are intended to
