Help Please
Dave_Notts
Hi folks I have a 2008 is220d and had the 3 quarter engine replacement and a new particulate filter / cat fitted now when driving a get a noise similar to the noise of the air con fans blowing at around 2200 revs and an intermittent juddering
Any ideas?
Cheers Dave
Difficult to comment on what it could be from the description, if the fault has been present from the time of the repair I would contact the dealer regarding the problem and get them to have a listen/look.
If it is as a result of the work they did it should be covered under warranty.
