Lifting An Ls430 With Air Suspension - Need To Run Engine Whilst Lifte
On the earlier models there was a switch to turn off the AS located in the toolbox area of the boot on the passenger side, have you not looked in your owners manual?
I just googled it and came up with this
http://www.clublexus.com/forums/ls430/350954-ul-on-a-car-lift-turn-off-air-ride-or-no.html
I'm not entirely sure what you asking, but if you are worried about 'blowing an airbag' it is impossible. The system will stop inflating the bags at a pre-set pressure, this has no relevance as to whether the car is on it's wheels or suspended in the air.
