Battery / Alarm
No that won't set the alarm off as long as the car is unlocked. You get about 5 beeps from inside the car when you disconnect it. Just lock each door manually then lock the drivers door with the key once your disconnected.
I always disconnect mine when going on holiday or leaving it stand for more than 3 days :)
