Keyed And Grumpy
kweilo
This happened a while ago...
But hell, since I'm going to keep her, subject to the heater matrix going in ok...
Any ideas?
I did the normal in terms of buffing down, t-cut (very very lightly) but... well is there anything I can do aside from look at a professional touch-up?
also try a harsh cutting compound first such as a g6 more gritted then a finer g10 then t-cut etc
its a way of cutting paint but in stages before wet sanding it as a cut and polich will be required after wet sanding if you do so rough cutting compounds are also a good try first
Is the car black? if so mix tcut colour restore with cut compunds also
