Wont Start
tallyho
So engine is cranking but not firing?
By any chance is the red alarm/immobiliser LED slowly flashing all the time?
If so turn the ignition on and leave at least 6 minutes when it should go out ( you may also hear a buzzing noise in the engine compartment which should also go off after the same time).
Engine should then start.
Hi can somebody help me out here, didnt use the car for about a month, battery went flat disconnected live terminal from battery left it on charge all night ,reconnected battery not even trying to fire,[that was atrickle charge,any ideas?????
Just for reference for you its neg terminal off for Battery removal first and then pos and pos first when putting Battery back on then neg just stops anything shorting out if you were to drop a spanner working live side with neg connected...
As for the problem did you mean its turning over and not firing or not turning over????
