Fitted a set of front brake disc's and pads to my father in laws LS today, whilst doing them found one of the calipers had part of a metal slider missing. It's the part where the edge of the brake pad sits on.its held in place by a button head screw in the middle of caliper but half has broken off so pad doesn't sit as square as it should. Can anyone tell me if these are available to buy and if so does anyone have a part number or exploded diagram please.
Sorry it's 1997 sept.
I've looked ay the exploded diagram and the part you describe is not listed as a spare part so I assume it is only available with a complete caliper.
Best suggestion I can offer is a look around the scrapyards if they are not all in the same state and you can actually remove it and the yard will let you just remove a piece as they normally want to sell the whole thing.
Ok thanks for your help appreciated . Is there any chance you can send me exploded picture of the caliper with the part in question so I can print off and see if I can source one please. Don't worry if can't do just thought it might help.
