I have a couple of little niggles with the LS400 that ive decided to sort out, can anyone advise me:
1) the rear courtesy/map lights on the c-pillars have never worked - but the ones next to the switch above the doors both work fine.
I've always presumed the pillar map lights should come on with the map light switch, or the door switch on opening - (ie in tandem with the map lights above door) - am i correct?
If so i presume I have either a wiring problem or two blown bulbs?
2) headlight washers have never worked - cant hear any pump/motor noise so presume pump is kapput or wiring problem or fuse gone? Is the pump under near side headlight? where do i find fuse ?
any help appreciated!
many thanks
marty
You got sorted out then mate, that's good.
sorry cant help with that problem mate. too new to the LS world to be able to help with much yet.
So any pictures then! :-)
i'll throw some piccies up when it stops raining Keith!
mechanically she's excellent, (apart from the above 2 little issues) - in amongst the service history is a garage bill from 2011 for major service and cambelt change - £1200 !!!!
cosmetically she's just beginning to show here age, so once i get the 2 niggles sorted i'll be moving on to the interior and exterior to try and bring her back to glory.
done 200 odd miles in her since yesterday, and averaged 29 mpg, which is the same as my mrs ford streetka !
in the manual it fuse for light washers fuse no 6 ,15 amp/pwr-iG fuse box drivers side insrument panel. As for map lights check bulbs first .theres a link on this site for a workshop msnual worth downloading , if you have any problem private me and i will email any info i have pics ect from manuals
You sound like you might know where the fuse would be for the incar phone as my cradle has suddenly stopped working, I have checked inside the engine bay fuse box but no luck there. Mike
Headlight washer pump is attached to the same container as the windscreen washers and located behind the nearside wheelarch liner more or less underneath where the Battery sits, the liner extends right under the bumper and is held by a combination of crosshead screws and 10mm bolts.
For the rear internal lights check the rear courtesy light switches.
engine bay fuse no33 tel 15 amp , hope this helps
Many thanks. First job in the morning. Mike
many thanks
marty
Headlamp washers only work with the lights on, have you tried that
