Knocking When Turning At Low Speeds (Parking)
petayV8
Hi ppl. My MOT is coming up in August so i want to iron out any potential problems. This is 1 of 2 that may come up.
When im turning quite sharply at low speed to back up into a parking space or driving slowly in say a car park, i get a knocking sound coming from the front brakes area when applying the brakes. Is this just the caliper moving a bit of something more serious. Any ideas?
Ill try and do a video if i get around to it
Did u see what I wrote on the ball joints thread?
jack your car up so the wheel is off the floor. Now hold the wheel at 12 and 6 o clock. Now push and pull at your wheel. It should be pretty solid. Also try it at 9 and 3 o clock. If there is a lot of play in the wheel then ball joint and excess play is an MOT failure
Jack your car up so the wheel is off the floor. Now hold the wheel at 12 and 6 o clock. Now push and pull at your wheel. It should be pretty solid. Also try it at 9 and 3 o clock. If there is a lot of play in the wheel then ball joint and excess play is an MOT failure
Checked all this just before winter hit, so 4 - 5 months ago. all checked out fine. Ill check again, it'll be up on the ramp again soon anyway before my road trip to France in July will be giving it a check over
If your ball joints appear to be intact, another known culprit is worn brake caliper slide pins.
Have a look here (credits to TigerFish):
http://www.lexusownersclub.co.uk/forum/tutorials/article/158-gs300-caliper-slide-pin-overhaul-plus-all-models-i-think/
Also, what is the state of your front lower arm bushes?
Well ill report back when i do a pre MOT check in a few weeks. Funny you should say that Rory its the same sound if i grab the caliper and try move it
