Hello From Lincolnshire!
wtf is200
Hi,had my Lexus is200 sport for two months and i love it.in that time ive fitted a front caliper,skimmed the discs using procut,the discs were fairly new fitted by the last owner so ok to skim.come to it this morning and found water in footwell.traced leak to sunroof drain pipe.wasn't connected.its met green with 136000miles on the clock.full history even have all the tax discs from New.lm a nissan mastertech s.o know a bit about cars.i love jap cars and hope to learn a bit more about my pride and joy on here.many thanks.richard
Welcome to LOC.
My previous LS had a blockage in the sun roof drainage holes, the car flooded one night in heavy rain causing the alarm to go off at 4am!! Something we should all be checking more often I think.
Phil
First, welcome to the Club, Richard!
Second, where are the sunroof drainage holes, Phil? I don't want this to happen to me, although so far so good. Many thanks, Pepe
Thanks for the welcomes guys.all sunroofs have drain holes.slide roof back.you can only see the front ones.if you poor water carefully around the hole it should go straight down them and dribble out of the sills,under the door.if nothing comes out,its going straight into the car.hope this helps some people.
As Richards says, two at the front and two at the back. The front ones are easy see, to locate the rear ones take slightly more careful looking but it's quite easy. The main thing is not to poke too hard and dislodge pipes. I used a very thick nylon line that I borrowed, and you don't need to push hard as it's usually just mush that causes the blockage. I seem to remember when I tested it the water from the rear holes came out under the rear wings.
Phil
