Is200 53 Plate
hi to be honest with you find that a bit strange,changed Battery on my car a few years ago with no problems what so ever,try disconnecting the Battery and reconnecting it and see what happens/if lights go out
Welcome to the LOC.
You recently had a flat Battery and after fixing it... what exactly did you do to fix it? Was the car jumped started by any chance, was the Battery accidentally connected the wrong way around momentarily before it was realised? It is quite easy to make that mistake with a Lexus as the terminals are often the other way around to other makes.
Was a Battery post disconnected with the engine running?
Simply replacing a car Battery should not result in the errors you have unless something happened during the fitment.
