Aerial Amplifier Wire?
I replaced my head unit with an after market Pioneer, using an amp bypass cable. It all works fine, however, the MW/FM reception is now pants, which I am assuming is because the aerial is no longer getting power?
Does anybody know which wire from the original loom carries the power?
The other end is from pin 13 on the main plug..plain black and should have other end of white connector on it. If you cant find it the aerial amp just needs a 12v feed through black wire.
Got it! Cheers Ian - FM and MW restored :D and I just fitted a DAB antenna for good measure!
@Pete - it was getting a bit dark to take a photo, but I can take one tomorrow if you like. To be honest, it's pretty obvious which wire it is, once you know what to look for. The head unit I installed was a Pioneer DEH-X6500DAB - absolute bargain considering features, power, etc. we're so spoiled when I think back to the head units I was installing 20 years ago!
